itcell8mdsr
Aug 09, 2024Follower
NAS No Volume Exists Error
I don't know what happened with my NAS, now when I am accessing its IP, it just shows, No Volume Exists, and further recommends that i create a volume before proceeding. I had 300GB of vital data tha...
Aug 10, 2024Guru - Experienced User
itcell8mdsr wrote:
Furthermore, it keeps saying remove inactive volumes to use the disk.
Don't do that, as it will result in data loss.
There are several potential causes for this, including multiple disk failures and power cuts.
Download the full log zip file from the logs page. The logs can be intimidating - if you need help sorting out what happened (or figuring out your recovery options), then you can send me a PM (private message) using the envelope link in the upper right of the forum page. Upload the log zip to cloud storage (dropbox, google drive, etc) and include a link to the zip in the post. Make sure the link permissions allow anyone with the link to download.
