mdgm-ntgr
Feb 17, 2015NETGEAR Employee Retired
NAS Not all drives are equal - choosing the right drive for you
One of the most important decisions you will make when purchasing a NAS is the decision as to which drives to purchase to put in it. Indeed depending on which NAS model and which drives you buy you c...
May 26, 2015Guru - Experienced User
There's an interesting study focused particularly on drive temps and failure rates here: http://www.cs.virginia.edu/~gurumurthi/ ... mtos13.pdf
Figure 5 shows that drive failure rate climbs steadily as the average drive temperature rises. The figure suggests that the ideal drive temperature range is ~27-33C.
cpu8088
Sep 15, 2015Virtuoso
"""The figure suggests that the ideal drive temperature range is ~27-33C."""
yea with ambient room temp at 30 C can u tell me which readynas can maintain hd temp at 27-33C? i mean without air conditioner running.
- StephenBSep 16, 2015Guru - Experienced User
As I'm sure you know, the readynas internal temp will always be ambient or higher.
Figure 5 in the link shows the impact of higher temps on disk failure rates as measured in the study. You can dismiss that data, or act on it - your choice.
Personally I've chosen WDC Reds partly because they are low in power consumption, and therefore run cooler. Most of my NAS are in my basement - not air conditioned, but usually cool even in summer. One is in my home office- in the summer the room air conditioner there is set to 30C when I am not working there. Disk spindown is also enabled.
Overall, disk temps might sometimes creep into the mid-30s, but generally they stay below 33C.
FWIW, I do wish Netgear would provide some knobs in the fan control, allowing people with power-hungry drives to run the fans more aggressively.
