babeal
Mar 02, 2018Aspirant
NAS Pro 6 on OS 6 network dropout
I know i'm unsupported but I wanted to check here to see if anyone is experiencing or has experienced the same issue. I upgraded my Pro 6 to OS 6.9.1. The nas runs fine but once a week the system n...
Mar 02, 2018Guru - Experienced User
Does it always happen at the same day/time?
- mdgm-ntgrMar 02, 2018NETGEAR Employee Retired
You can send me a copy of your logs if you like (see the Sending Logs link in my sig).
- babealMar 02, 2018Aspirant
I sent the logs. The time it occurred last was around this time Feb 26 18:52:13
I see you're running the Transmission app. Are you using any other apps?
Which services are you running?
- babealMar 19, 2018Aspirant
So i got back from a business trip turned the unit on and then it worked for a day but now I am getting the boot to "ReadyNas" screen. It's strange that it auto boots when i flick the power switch on and doesn't need me to press the power button on the front. I tried holding the boot menu (reset) switch at the back but nothing happens. I tried every thing in previous posts like removing all the disks as well. There are a couple of posts mentioning something about a usb stick but all of those links are dead. Is there a usb method to try?
- StephenBMar 19, 2018Guru - Experienced User
Try powering down and removing the disks (labeling by slot number).
Then boot up, and run RAIDar on a PC. Let us know if RAIDar detects the NAS and reports a "no disks" status.
https://kb.netgear.com/20684/ReadyNAS-Downloads
- babealMar 02, 2018AspirantI don’t think so but I really haven’t been keeping track. I can start paying attention to it. What would the timing be related to?
