AlanBoats
May 21, 2018Aspirant
NAS won't boot
Hi, used my NAS for a few years now and then had problems connecting to it. I logged into it and all was OK but showed a Firmware update was available so did the update. All whet OK and could acces...
JohnCM_S
May 22, 2018NETGEAR Employee Retired
Hi AlanBoats,
Can RAIDar detect the NAS? If it is not detected,
1. Turn off the NAS
2. Remove the drives (Note: Please label with its corresponding bay before you remove them.) and then power on the NAS
3. Check if RAIDar can detect the NAS without the disks.
AlanBoats
May 22, 2018Aspirant
Hi,
OK steps 1 and 2 done.
When I restarted the NAS the power LED flashed 16 times, stayed on for about 7 seconds, flashed one more time and then the light went out. No other lights flashed in the front of the NAS. The fan still runs.
I cannot see the NAS on my home network map.
How can I check if RAID can detect the NAS without the disks?
Alan
