AlanBoats
May 21, 2018Aspirant
NAS won't boot
Hi, used my NAS for a few years now and then had problems connecting to it. I logged into it and all was OK but showed a Firmware update was available so did the update. All whet OK and could acces...
JohnCM_S
May 22, 2018NETGEAR Employee Retired
Hi AlanBoats,
Can RAIDar detect the NAS? If it is not detected,
1. Turn off the NAS
2. Remove the drives (Note: Please label with its corresponding bay before you remove them.) and then power on the NAS
3. Check if RAIDar can detect the NAS without the disks.
JohnCM_S
Hi AlanBoats,
If you have the RAIDar installed on your computer, it should detect the NAS with a status of 'no disks detected'.
You may download the installer here.
- AlanBoatsMay 22, 2018Aspirant
John,
RAIDar downloaded and launched. It could NOT detect the NAS.
Alan
- JohnCM_SMay 24, 2018NETGEAR Employee Retired
Hi AlanBoats,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
