coslad73
Mar 14, 2016Aspirant
nas102 over 30 hours for the first use? not possible!
Hi everyone, 2 days ago I have bought a nas102 diskless. I have putted inside a 2tb hdd. Following the discover instruction nothing happened, the online page didn't discovered the nas ,even though I ...
- Mar 17, 2016
HI
i solved , i don't know how !
1) I putted inside a old 1tb hdd, the system started
2) In the admin web page i made an firmware update
3) I putted together the 1tb hdd with the new 2tb hdd
4) the system tells me that it needs a sync,after 4 hour the sync is finished
5) i left only the new 2tb hdd ,made a format and now it worksNow a question :
can i put inside two different hdd ,disabling the raid and get the sum of the two hdd ?
kohdee
Mar 16, 2016Administrator
When the ReadyNAS says that there is a disk with data on it and you need to get rid of the data before it can be used, then the disk itself had existing data. You get the same thing after factory deaulting?
Telnet is open but is for tech support mode use.
- coslad73Mar 17, 2016Aspirant
HI
can i put inside two different hdd ,disabling the raid and get the sum of the two hdd ?- StephenBMar 17, 2016Guru - Experienced User
coslad73 wrote:
HI
can i put inside two different hdd ,disabling the raid and get the sum of the two hdd ?If you'd done the reset with only one drive in place, you could have done it easily.
Now you need to do another reset. Best to do it with one drive in place. Then change to flexraid before you insert the second drive.
