immagikman
Mar 18, 2014Aspirant
Need a solution for 60TB+
What I want to do is eventually have about 60TB or more of DVD and BluRay ISO images online for my media server.
Currently Im using a ReadyNAS Pro 6 and a ReadyNAS Ultra 6 each loaded with 3TB drives They are at full capacity now
And I figure 60TB will give me the headroom I will need for my current plans.
So essentially I need a platform that will handle 36TB initially and be able to expand to about 60TB or more.
Not sure if the 5200 series will give me the functionality I need and I may be missing something simpler or more
cost effective.
So any input would be appreciated.
cost effective.
- StephenBGuru - Experienced UserAn RN516 + 3 EDA500 extenders can reach 84 TB with 4 TB drives. If you are using XRAID2 with single redundancy, it would go down to 68TB (4 volumes, 6x4TB, 5x4TB, 5x4TB, 5x4TB). This would be cheaper than ReadyDATA 5200 + EDA4000 extenders (and probably quieter).
Also, note that 5 TB (and even 6 TB) drives are beginning to appear, which will increase these capacities. Though the 6 TB drives are extremely expensive.
Do you really need this on a single NAS? Deploying multiple NAS might be more flexible. - immagikmanAspirantWell NEED no...dont NEED a single NAS but Seeing as how all the images are related and it would be a pain trying to balance the content across multiple platforms....The appeal of one large storage area seems very nice.
Right now I have the load spread across a ReadyNAS 314, RN Pro and an RN Ultra 6 Pro...and this is why I was looking for a single storage pool solution. - StephenBGuru - Experienced UserYou would still have to spread the storage across multiple volume. The more disks in the RAID array, the more fragile it is.
- http://blog.backblaze.com/category/storage-pod/
of course that does not include OS, you would have to determine best os and raid format(s) to use - StephenBGuru - Experienced User
The site to purchase it is here: http://45drives.com/products/direct-wired-standard.php About $5400 US for one unit with non-redundant power supply (and it does come with the OS installed). Though I don't see any info about the OS.TeknoJnky wrote: http://blog.backblaze.com/category/storage-pod/
RAID format is an interesting question for 45 drives. Here's what backblaze does:Each Storage Pod of 45 drives is logically divided into 3 RAID arrays utilizing RAID 6 for redundancy. Given the physical layout of a Storage Pod of 3 rows of 15 drives each, you might assume each row is a RAID array, but it’s not. In each row, every 3rd drive is a member of the same RAID array. This is done to spread a given array across all 9 of the backplanes the drives plug into. It also minimizes the impact on a given array if a backplane fails.
So they would allocate 6 drives for redundancy, giving you 156 TB if you used 45x4TB. And they'd provide 3 volumes. - rit1AspirantFor that type of capacity you may like to look at general server equipment and then build out a Linux (or Windows) server that can operate as a large scale file server. One hardware vendor that does some very nice cases for large disk arrays is SuperMicro as can be seen from this
http://www.supermicro.nl/products/syste ... R72L2K.cfm
Its design supports up to 72 drives across 3 controllers.
Just find a reseller that can add disks, memory and processor(s) that meet your requirements, which will very much depend on the type of file system deployed. - StephenBGuru - Experienced UserAlso keep in mind that this class of equipment is usually very noisy - and the noise level is not spec'd since it isn't intended for home installations. So you should make sure you have a location for it where the noise doesn't matter.
- rit1Aspirant
StephenB wrote: Also keep in mind that this class of equipment is usually very noisy - and the noise level is not spec'd since it isn't intended for home installations. So you should make sure you have a location for it where the noise doesn't matter.
For a supermicro solution think jet engine as a 72 drive system would be in the 1.5-2KW heat output range :) - immagikmanAspirantThe unit is in a nice cool dry corner of the basement next to my 24 port Gigabit switch..the house is wired with cat5e or cat 6 cant remember which
This is really just an extravagance for me, Im filling the space with riped DVD's and BluRays I own....the Television shows with several seasons of content really take up space..especially the ones in BluRay. So I rip them all to ISO format and then pack the Physical media away in nice clean containers. - immagikmanAspirantThose Storage Pods look nice but are probably much more than I need.
Maybe EMC will have a clearance sale and Ill pick up one of their old SAN units ;)
