Big_Dogg
Sep 04, 2024Aspirant
Need Help - ReadyNAS Ultra 4 - Access
Good day, Im sorry if this is in the wrong section, I didnt see any that seemed to be specifically for the NAS products. As this listed as General I thought Id start here. I have a Netgear Read...
Sep 04, 2024Guru - Experienced User
Big_Dogg wrote:
Ok, did that, reset the password, BUT when I attempt to access the NAS I either get a screen that tells me there are no "shares"
Make sure you have /admin at the end of the URL. (https://nas-ip-address/admin - using the real NAS IP address of course). If you run into the SSL protocol/CIPHER mismatch error in your browser, post back.
This is a clue that your NAS is running 4.2.x firmware. It can be converted to run OS-6, so that is something to consider.
The default password for 4.2.x is netgear1. The default for 6.x firmware is password.
Big_Dogg wrote:
when I click on the drive shown in the network listings I get a screen that tells me an error (error 0x80004002 : No such interface supported)
First get into the web admin ui, and set the admin password you want. It's best not to use the default. Also see if you created any user accounts. If you did, then you likely need to reset the password for the user account also.
Then if you are running 4.2.x firmware, go into "turn windows features on or off" and make sure the SMB 1/CIFS client is enabled.
Try entering \\nas-ip-address in the file explorer address bar (again using the real NAS IP). Make sure you are using the correct slash - // will open your web browser, which is not what you want.
You might also need add the NAS credentials to the Windows Credential Manager.
- SandsharkSep 04, 2024Sensei
"No shares" is likely just telling you you haven't enabled HTTP(S) access for any shares (it's off by default), not that the shares are gone, unless you inadvertently did a "Factory Default" (which does wipe the NAS) instead of an "OS Reinstall". So don't panic, just let StephenB guide you to access them.
