rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
RX
May 29, 2015Luminary
First, kindly check if you have a Duo v1 or Duo v2: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
After doing the step above, I suggest that you perform OS reinstall. OS reinstall will set the password back to its default ("netgear1" for Duo v1 and "password" for Duov2). Also, the NAS will be set back as being a DHCP client and this will not delete any data saved in the NAS. http://kb.netgear.com/app/answers/detai ... -boot-menu
