rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
vandermerwe
May 29, 2015Master
OP has a Duo v1.
Have you upgraded your firmware, you were on some old firmware in January.
The OS reinstall is the quickest way to sort this out.
Does raidar not see the nas?
Have you considered dhcp with reserved addresses.
Although an OS reinstall is safe, you should have an up to date backup, always but especially during episodes like this.
