rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
RX
May 29, 2015Luminary
rebop wrote: Is it safe to reboot or could that make things worse?
Its alright to reboot your Duo v1 and check if it will boot up normally. If ever that you still cannot access frontview, then perform OS reinstall: http://kb.netgear.com/app/answers/detail/a_id/24874
