rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
May 30, 2015Guru - Experienced User
If your new router supports address reservation (most do), then I suggest using that instead of assigning a fixed IP address.
That ensures that the issue won't happen again with future routers.
