rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
BaJohn
May 30, 2015Virtuoso
Me too. Also provides a little bit of extra security, as I currently have 31 IP addresses available and 31 allocated. The downside is that every time a new item needs to access the network, you have to make changes to the Router, as there are no free IP addresses.
StephenB wrote: Me too. I reserve addresses for pretty much everything, not just the NAS. It's easy to do, and sometimes helps when troubleshooting router/connectivity issues.
ukbobboy wrote: In fact, I have used the same technique fix the IPs for three smart phones, my android tablet and several other internet enabled devices.
NOTE:- Some people believe this is not a good idea, but it is my preferential way of setting it up.
