rebop
May 29, 2015Tutor
Need help once again please!
Please move this if in the wrong place. I had a fixed IP on my ReadyNas Duo. I switched from DSL to cable, so the network changed from 192.168.1.xxx to 192.168.0.xxx. I went in to (forgot what you ...
May 30, 2015Guru - Experienced User
That's the downside of using static addresses.
You likely could have configured the new router to use 192.168.1.x too - but that ship has sailed and at this point there is no reason to go through the pain again.
