uptown30
Oct 05, 2016Guide
NetGear 314E hard drive
Hi we have a NetGear ReadyNas 314E which is getting to run out of diskspace. Is it possible to upgrade the drive from 8 Terabyte to 16 or 31 TB? Would there be any issue if I upgrade them beside th...
- Oct 05, 2016
You can upgrade (there is a hardware compatibility list here: http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list?cid=wmt_netgear_organic )
Of course anything you replace isn't covered by Netgear's drive warranty.
Oct 05, 2016Guru - Experienced User
