antongibbs
Aug 21, 2011Aspirant
Netgear duo windows 7
Hi , I’m hoping someone would be able to assist me with a problem I have with a Netgrear nas duo it works totally ok on my 32 bit windows XP sp3 Machine, however I have an odd problem with raidar on ...
antongibbs
Aug 22, 2011Aspirant
Thanks for those pointers papabear, none of which had the desired effect unfortunately, the error code I’m getting is “0x80070035 network path not found”, the weird thing is as i said before was that i can access setup via Raidar but i guess that’s because it’s on a different IP address.
