antongibbs
Aug 21, 2011Aspirant
Netgear duo windows 7
Hi , I’m hoping someone would be able to assist me with a problem I have with a Netgrear nas duo it works totally ok on my 32 bit windows XP sp3 Machine, however I have an odd problem with raidar on ...
PapaBear1
Aug 26, 2011Apprentice
That is your Duo. I don't know why it is showing up twice.
But I did note that in your original post you were trying to connect to 192.168.1.64 yet in the map the Duo is showing up as 192.168.1.66.
What happens if you enter "https://192.168.1.66/admin/" in your browser window (without the quotes)?
