antongibbs
Aug 21, 2011Aspirant
Netgear duo windows 7
Hi , I’m hoping someone would be able to assist me with a problem I have with a Netgrear nas duo it works totally ok on my 32 bit windows XP sp3 Machine, however I have an odd problem with raidar on ...
PapaBear1
Aug 28, 2011Apprentice
What I was wanting you to try was to connect the desktop to the router with ethernet cable to establish whether it is actually Windows or the wireless adapter.
Can you snip an image of the Network and Sharing Center and also the M-R section of the Allowed Programs window as above and post them? Snipping Tool makes this fairly easy. If you have not used it before, it is found under accessories (Start -> All Programs -> Accessories).
