salt93
Oct 17, 2025Follower
NETGEAR Mobile Broadband Driver
Hello, I’m currently using the MR1100 (Nighthawk M1) mobile router and need to reinstall the “NETGEAR Mobile Broadband Driver (V8.2.1.0)” for Windows. However, the official link (https://downloa...
Oct 17, 2025Guru - Experienced User
salt93 wrote:“NETGEAR Mobile Broadband Driver (V8.2.1.0)” for Windows.
This is not listed in the support downloads for the MR1100
And googling with site:netgear.com doesn't give any hits.
FWIW, I am puzzled on why you'd need a windows driver. Normally you'd connect to the hotspot using normal WiFi, ethernet, or USB-C. None should require any windows drivers.
