Serj_82
Nov 30, 2019Aspirant
Netgear NV+ (RND 4000) - how to connect large discs without formatting
Hello. I purchased a device for the ability to connect four disks to it - 2 by 3 TB and 2 by 2 TB. Use as a storage of different files. Questions: 1) Does the device support large disks? What is t...
Serj_82
Dec 01, 2019Aspirant
Thank you!
Tell me please, whether the device is working with X-RAID2?
Dec 01, 2019Guru - Experienced User
Serj_82 wrote:
Thank you!
No, it uses the original XRAID. That supports adding disks to empty slots ("horizontal" expansion).
If you were to upgrade disks to a larger size later ("vertical" expansion), you'd need to upgrade all four before the array would expand. Though with the 2 TB size limit, you'd be better off just starting with 2 TB drives.
Also, your ReadyNAS only supports SMB/CIFS 1.0, which is being deprecated by both Microsoft and Apple.
My own NV+ is still in service, but I only use it as a backup of my main NAS.
