bhmstuff
Apr 02, 2016Aspirant
Netgear ReadyNas 102 Disconnects from Network
Hello everyone! I've had the Netgear ReadyNas 102 for a couple of years now I guess and haven't really had many issues with it. Recently, I've been experiencing frequent drops from the network that r...
Apr 02, 2016Guru - Experienced User
Are you comfortable with linux commands?
What apps do you have installed? Do you have ReadyDLNA enabled?
What firmware are you running?
- bhmstuffApr 03, 2016Aspirant
I'm currently running the latest version of the firmware available - 6.4.2
ReadyDLNA is enabled along with SMB, AFP, HTTP, HTTPS, iTunes, UPnP
The only app I have installed is Plex Media Server.
I'd be OK with running Linux commands as long as I knew how/where to run them. I haven't messed with Linux in quite some time.
Thanks!
- StephenBApr 03, 2016Guru - Experienced User
The OS partition is 4 GB, and it might be getting full.
If you enable ssh in on the services page, you can then access with putty. The username is "root", the password is the NAS admin password.
Checking for OS fullness is easy, just enter
df . -i
df . -h
and post the results here.
Looks like the partition you mentioned is OK.
login as: root
root@10.0.0.149's password:Welcome to ReadyNASOS 6.4.2
root@Hoth:~# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 11542 53994 18% /
root@Hoth:~# df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 493M 3.3G 13% /
root@Hoth:~#Any other guesses? I reset the system this morning (around 9:00 AM) and it's still connected now. Just have no idea how long it will stay that way.
Thanks so much for the help!
