bhmstuff
Apr 02, 2016Aspirant
Netgear ReadyNas 102 Disconnects from Network
Hello everyone! I've had the Netgear ReadyNas 102 for a couple of years now I guess and haven't really had many issues with it. Recently, I've been experiencing frequent drops from the network that r...
bhmstuff
Apr 03, 2016Aspirant
Yes, it is disabled.
Apr 04, 2016Guru - Experienced User
How full is the data volume? Have you recently defragged/balanced it?
- bhmstuffApr 04, 2016Aspirant
I'm going by memory, but there should be plenty of space. I want to say there are close to 2 TB free. I haven't defragged / balanced it. Is that something that I should look into doing? I haven't done any type of maintenance on this since I've had it set up. I can definitely do so if that might help.
- StephenBApr 04, 2016Guru - Experienced User
I do suggest running all the volume maitenance functions - I schedule each of them to run once/quarter.
Though of course the NAS shouldn't disconnect from the network...
- mdgm-ntgrApr 04, 2016NETGEAR Employee Retired
bhmstuff can you send me your logs (see the Sending Logs link in my sig)?
