b4pjoe
Jan 09, 2024Aspirant
Netgear ReadyNAS 104 won't power up.
On Sunday at 3:15 pm I got an email notification that reads "Detected high spin retry count: [262144] on disk 1 (Internal) [TOSHIBA DT01ACA200, Y2S3T8DAS]. This condition often indicates an impendin...
- Jan 16, 2024
I decided to risk the $26 for the new power supply. Got it today and it started right up with the new power supply so case is solved. Bad power supply.
Jan 09, 2024Guru - Experienced User
b4pjoe wrote:
After I put the drives back into the NAS I tried to power it up and it powered up and booted but I was not in a location with an ethernet cable so I could not access it so I powered it off, moved it back into it's location, plugged in the ethernet cable and it will now not power back up. No lights and no thing. Removed the ethernet cable and still won't power up. Removed the drives and still won't power up. Put the drives back in and still won't power back up.
Have you tried plugging something else into the main power outlet? I'm wondering if you tripped a breaker.
b4pjoe
I've tried it on several outlets and I know they are all still working for other stuff. Also I looked at the breakers. No breakers switched to off.
- SandsharkJan 10, 2024Sensei
You may have an issue with the power pack or the power connection on the NAS. Did you try wiggling the connection to see if it made a difference? As StephenB stated, buying a replacement supply may be a good thing to try. If you have another 5V supply without at least 1A of capacity and the right connector, you could try powering it up using that supply without the drives. Under no circumstances should you try it with the drives and an underrated supply, you could do a lot of damage. But if it powers up empty with a lower-rated supply, you know for sure the power pack is the issue.
- b4pjoeJan 10, 2024Aspirant
I have tried wiggling the connector and it doesn't help. The two times it did power up it was just a straight plug it in and it powered on. I have tried it with no drives in it. I never got power anytime with no drives in it. If it makes any difference the green light on the power supply does come on. Not sure if that means it is OK or if it just has enough power to light the green light up.
I checked the output of the power supply and it is at 12 V DC.
- SandsharkJan 11, 2024Sensei
That the green light comes on and the output measures 12V without a load are not necessarily an indication that the supply is providing sufficient power under load. But that it did power up a couple times with the drives and won't at all does tend to point to that not being the issue. You may have a problem with one of the voltage regulators within the NAS that produces the voltages needed (5V and 3.3V). That's a non-repairable problem. But it also could still be just a bad connection of the power supply, even if wiggling didn't have any effect.
I think it's highly doubtful that the drives caused the issue. In fact, I think it's more likely that insufficient voltage to the drives caused those error messages and the drives are actually fine.
