StanTheMan01
Oct 17, 2016Aspirant
Netgear ReadyNas 212 & WebDav Over HTTPS Not working!
Hi all, Recently got a Ready Nas 212 and i'm struggling using WebDav over HTTPS. WebDav Over HTTP works fine, I can add it as a network location, or map it as a drive and it works fine. I...
StanTheMan01
Oct 18, 2016Aspirant
Hi Jennc,
Thanks for the reply. Yes, HTTPS is enabled, in fact, over a web browser, I can access the https interface of my shared folder and view the files in a browser, but using WebDav, it refuses to work.
Any ideas?
Thanks
JennC
Oct 18, 2016NETGEAR Employee Retired
Hello StanTheMan01,
Can you try this on another computer? Add or create a drive letter pointing to https://<NAS IP>
- StephenBOct 18, 2016Guru - Experienced User
There is a patch for webdav here: https://community.netgear.com/t5/Using-your-ReadyNAS/Error-while-uploading-with-webdav-after-upgrading-to-6-6-0/m-p/1156799/highlight/true#M118031
It might not be relevant for your issue, but perhaps worth a try.
