StanTheMan01
Oct 17, 2016Aspirant
Netgear ReadyNas 212 & WebDav Over HTTPS Not working!
Hi all, Recently got a Ready Nas 212 and i'm struggling using WebDav over HTTPS. WebDav Over HTTP works fine, I can add it as a network location, or map it as a drive and it works fine. I...
StanTheMan01
Oct 19, 2016Aspirant
Thanks for the replies.
I tried mapping the network drive as https://ipaddress I get prompted for a username/password and after entering them i get an error "a device attached to the system is not functioning"
So I tried mapping https://ipaddress/Share (Share is the actual name of my share) and i get the error 'unexpected network error occured'
I also installed the patch for WebDav that was suggested and this also didn't help.
If I map the drive as http://ipaddress/Share it works fine.
This is definetly something specific to webdav and HTTPS. I'm not sure if this is an issue with Netgear implementation or if it's a Windows issue. I've now tried a Windows 7 machine, a Windows 8 machine, and a Windows 10 machine all with the same problem.
Thanks
- JennCOct 19, 2016NETGEAR Employee Retired
Hello StanTheMan01,
How about changing the share name to a unique one?
- JennCOct 24, 2016NETGEAR Employee Retired
Hello StanTheMan01,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- IT-SWOct 25, 2016Guide
I have this same issue on my Rn3138 and my 312. Would love to have a solution to this.
