StanTheMan01
Oct 17, 2016Aspirant
Netgear ReadyNas 212 & WebDav Over HTTPS Not working!
Hi all, Recently got a Ready Nas 212 and i'm struggling using WebDav over HTTPS. WebDav Over HTTP works fine, I can add it as a network location, or map it as a drive and it works fine. I...
StanTheMan01
Oct 19, 2016Aspirant
Thanks for the replies.
I tried mapping the network drive as https://ipaddress I get prompted for a username/password and after entering them i get an error "a device attached to the system is not functioning"
So I tried mapping https://ipaddress/Share (Share is the actual name of my share) and i get the error 'unexpected network error occured'
I also installed the patch for WebDav that was suggested and this also didn't help.
If I map the drive as http://ipaddress/Share it works fine.
This is definetly something specific to webdav and HTTPS. I'm not sure if this is an issue with Netgear implementation or if it's a Windows issue. I've now tried a Windows 7 machine, a Windows 8 machine, and a Windows 10 machine all with the same problem.
Thanks
JennC
Oct 19, 2016NETGEAR Employee Retired
Hello StanTheMan01,
How about changing the share name to a unique one?
