itsgbp's avatar
itsgbp
Follower
Feb 25, 2026
Netgear ReadyNAS 3312 Not Booting
I am using a Netgear ReadyNAS 3312 (12-bay model). After rebooting the NAS, it powered on but is not responding to ping. The power LED (blue) and Network  LED (yellow) are continuously blinking.
Please help
  • StephenB's avatar
    Does it respond when you power down, remove the disks, and then power up again?  Label the disks as you remove them, so you can return them to the proper slots.  (Also, when you do return them, make sure the NAS is powered down).
  • And what does RAIDar indicate in both cases -- with and without drives?
    • JoVe34's avatar
      JoVe34
      Guide
      Hello Sandshark,
      What kind of indication this "RAIDar" App. is expected to give us? I'm not exactly in the same situation, but I suspect this could help me ...
      Thanks in advance,
      • StephenB's avatar
        One thing it has for OS-6 systems is a diagnostic.
        Best to start your own discussion with the details of your issue - it can get quite confusing to try to reply to more than one person on the same thread.
ProSupport for Business
