itsgbp
Feb 25, 2026Follower
Netgear ReadyNAS 3312 Not Booting
I am using a Netgear ReadyNAS 3312 (12-bay model). After rebooting the NAS, it powered on but is not responding to ping. The power LED (blue) and Network LED (yellow) are continuously blinking.
Please help
- SandsharkSensei
And what does RAIDar indicate in both cases -- with and without drives?
- JoVe34Guide
Hello Sandshark,
What kind of indication this "RAIDar" App. is expected to give us? I'm not exactly in the same situation, but I suspect this could help me ...
Thanks in advance,
One thing it has for OS-6 systems is a diagnostic.
Best to start your own discussion with the details of your issue - it can get quite confusing to try to reply to more than one person on the same thread.
Does it respond when you power down, remove the disks, and then power up again? Label the disks as you remove them, so you can return them to the proper slots. (Also, when you do return them, make sure the NAS is powered down).
