stevewaugh3
Oct 22, 2021Follower
Netgear ReadyNAS NV+
I Was trying to access NAS (Raid 1 setup), drive went away from windows explorer. Manualy rebooted NAS, NAS won't start. The PSU went bad. Since this NAS is very old I'ld like to upgrade and move the...
Oct 23, 2021Guru - Experienced User
stevewaugh3 wrote:
Where Im lost is once I assine a drive letter (using to the EXT3 volume then try to access the content via Windows Explorer I get a bunch of random folders.
What folders are you seeing? I am guessing they are in the OS partition /etc, /lib, /usr, /var, etc).
The problem with accessing the data volume is that you also need the RAID tools (LVM). Try r-studio instead. https://www.r-studio.com/
You can download for free - if it works, you will need to purchase it to actually offload the data.
