michelwallens
Feb 21, 2021Aspirant
Netgear ReadyNas Ultra 6 and Frontview
Hello I bought a broken ReadyNas Ultra 6. I managed to start the NAS. Its flash memory is damaged and impossible to flash it because no access to the USB Boot. In windows it is recognized by a ...
mdgm
Feb 21, 2021Virtuoso
Yes, provided the internal flash memory is O.K. it’s possible to fix that via telnet. I have done it many times.
This of course also assumes that the problem is on the flash (seems likely).
Only seeing one of your screenshots my guess is corrupt EEPROM.
- michelwallensFeb 21, 2021Aspirant
Hello.
I will try to send you frame by frame. I don't know why I can't seem to put them in my original post.
Thank you. - michelwallensFeb 21, 2021Aspirant
