madesimplemedia
Oct 19, 2015Aspirant
NETGEAR RN202-100NES ReadyNAS 202 2 Bay - Questions
Hi, I'm thinking about this NAS for my home office. I have a few questions: 1) Drive compatibility - I'm thinking about using 2 Crucial SSD drives, are there any drive compatibility issues t...
Oct 19, 2015Guru - Experienced User
madesimplemedia wrote:
1) Drive compatibility - I'm thinking about using 2 Crucial SSD drives, are there any drive compatibility issues to check?
The disk compatibility list is here: http://kb.netgear.com/app/answers/detail/a_id/20641 Netgear hasn't invested much time in qualifying SSDs. I suspect your drives will work, but if they are not on the list Netgear can (usually will) deny support.
I suggest jbod for SSDs.
2) I want to backup data from my web server to the NAS. Can I set FTP details on the NAS so I can get the server to direcly upload backups to it.
You can enable FTP access for a share. You'd need to forward ports in the router of course.
3) I see it has dual Gigabit ethernet, do you plug both ports into the router and get twice the speed?
The product supports NIC bonding. LACP requires both ends (NAS and router) to support it, there are some bonding modes in the NAS that work with any router.
You won't see twice the speed for a single user, but total throughput can be increased if you have several users.
4) I use both PC and Mac, anything I need to be aware of in terms of file types/format, fomatting the drives etc to make sure it all works?
You install the drives unformated. The NAS formats them (ext for the OS partition, BTRFS for the data)
5) Can I install 2.5" drives without any adaptors?
Yes.
- madesimplemediaOct 19, 2015Aspirant
Hi Stephen
Thanks for the information, very helpful :)
Dave
