Moonge
Apr 04, 2024Aspirant
NetGear Rn31400 still useable in 2024?
At work while cleaning out some stuff from our data center we came across a netgear rn31400 nas. This was from one of the doctor offices we bought out and put in all of our own equipment. Think the D...
Moonge
I've had really good luck with the WD blues previously and will probably grab those again. I have 2 of them in the sharecenter I have been running for awhile so that way they will all be same rpms.
Apr 04, 2024Guru - Experienced User
Generally I recommend
- Seagate Ironwolf
- WD Red Plus (but NOT WD Red)
- Any enterprise class drive.
If you pick a desktop-class drive, then check the datasheet and make sure it isn't SMR.
