Poland3320
Jul 05, 2024Aspirant
Netgear RN3320 not working properly
Hello, I'm having difficulties running Negear RN3320. Few days ago, SMB access to files started working very slow and I was almost immposible to read/open any files. Web interface loads very slow, ...
Jul 05, 2024Guru - Experienced User
Poland3320 wrote:
Is it possible to switch disks between two identical RN3320 chassis without problems? Maybe RN3200 chassis has it's own OS(NAS has OS6 AFAIK) and when we connect all disks, new NAS will erase all data?
Yes. The NAS boots from the disks, and all the configuration information is stored on the disks.
However, one factor is that there is a firmware install file in the NAS flash. If the firmware in that file is newer than what is running on the NAS, then the disks will be updated to that version when the NAS boots. You should avoid that, so make a note of what firmware is currently running on the NAS. You can then make sure you install the same version on the replacement (using a scratch disk, not a disk in the array).
Note that if the firmware in the flash is older than that is on the disks, then the flash is updated from the disks That of course is ok in this situation.
Poland3320 wrote:
We's started diagnosing the problem. All 12 disks are ok, no errors, no S.M.A.R.T errors.
Network cables are fine too, no CRC, retransmissions etc.
The absence of S.M.A.R.T errors is not enough to confirm that the disks are ok. Have you downloaded the full log zip file, and looked for errors there?
Also, do you have a backup of the data on the NAS?
Sandshark
Jul 05, 2024Sensei
From SSH, execute top and see if any processes are using an excessive amount of CPU time.
- Poland3320Jul 08, 2024Aspirant
Sandshark wrote:From SSH, execute top and see if any processes are using an excessive amount of CPU time.
Commad top gave me strange results. CPU utilisation is at about 5 % and only 1 process running. Evertting looks like hardware and OS problem.
- StephenBJul 08, 2024Guru - Experienced User
Poland3320 wrote:
Commad top gave me strange results. CPU utilisation is at about 5 % and only 1 process running. Evertting looks like OS problem.
How full is the OS partition?
Use this to check:
mount --bind / /mnt btrfs fi df /mnt btrfs fi show /mnt - SandsharkJul 08, 2024Sensei
Only one process running? I don't see how that can be. Did you log on as root?
