vGtO
Aug 18, 2023Aspirant
Netgear Stora MS2000 cannot access after hard reset
Help anyone?! According to our provider our Netgear Stora had been hacked and was sending spam. There was no way I could change the password so I finely decided to make a hard reset, convinced that ...
Aug 18, 2023Guru - Experienced User
vGtO wrote:
Help anyone?!
According to our provider our Netgear Stora had been hacked and was sending spam. There was no way I could change the password so I finely decided to make a hard reset, convinced that I could setup again... But no way you can reinstall the software or make a new setup because whatever you try, the software wants to go to mystora.com which doesn't exist anymore.
I desperately need those files! Anyone a solution on how to reach them?
Netgear won't help...even though they still have the non functioning software as a download on their website.
Thnx in advance! Terry
As you say, Netgear won't help and AFAICT there is no way to set up the Stora since they took down www.mystora.com. back in 2020.
I believe the file system is XFS, which you should be able to mount on a linux system.
Not sure if this will be enough, but it might be a useful start:
This might also be helpful:
You could also try this package from Paragon - it might let you read the files on a Windows PC (after you connect the drive to the PC using either SATA or a USB adapter/dock).
Note I've never owned a Stora, so I have no direct experience with it.
- vGtOAug 19, 2023Aspirant
Thnx Stephen! I'm glad that at least the Netgear community is still alive. I'm going for your 3rd option now. A hardware guy is looking into how to connect the Stora to my Windows 10 laptop now. The Paragon software cannot mount the Stora through the modem.
- SandsharkAug 19, 2023Sensei
You won't be able to use the Stora itself for this. You'll need a USB dock. The Stora isn't accessible via USB.
