riovine
Sep 26, 2011Aspirant
New 4.1.8 (NV+ sparc) upgrade does not detect USB disks
I just upgraded my NV+ sparc with the latest 4.1.8 firmware. Now it will no longer find my attached USB disks that I use to backup my entire NAS. I have several disks hanging off a USB hub and have ...
arjoseph1
Sep 28, 2011Tutor
Try to downgrade to 4.1.7, if it will work then you have to contact support so that they can assist you further. Once you get a case #, please edit the subject of your post and add the case # at the end. Thanks.
