davesfolly
Jul 15, 2021Aspirant
new hdd is black, and degraded
OK got new hdd, turned off the unit, installed, back on I have that issue. I've tried to format the drive, but no change.
davesfolly
Jul 20, 2021Aspirant
OK, thanks for that info. Now I took the HDD to a windows computer, and formatted it ex fat. now it's here. I've read a lotta threadss, and dont know what to do next. Help. and thanks
Jul 20, 2021Guru - Experienced User
You'll either need to format it again in the NAS, or put it back into the Windows computer and unformat it.
You can unformat it using the windows disk manager - selecting and deleting each partition ("volume" is what Windows calls them) on the disk. After that, hot-insert it into the NAS.
