martin19's avatar
martin19
New to ReadyNas Need help please
Hi All
Im a stranger here and really need adivce, i have a Readynas Duo V2 for over 4 years now with no problems, i had 1 x single 2TB WD Red HDD and running out of space, i now just purcahesed a new 6TB WD Red Nas HDD, i took out the old 2Tb and installed the new 6TB works great, i thought i could then just use an external HDD plug in usb cradle and copy over the files to the new HDD, well i thoght wrong and did not work, i then put the old 2 TB back in the NAS and pulled out the new 6TB one, and now it wants me to reset it up which i dont want to do as i would loose eveything, or would I?
The question i have is how to access the files and data on my old 2TB HDD thru a windows operating system and copy thru to the new 6TB NAS HDD, i would appreciate some help please.
Thank you
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What you're proposing is not straightforward. What you should have done is backup the data from the 2TB disk onto a USB disk. Then power down, remove the 2TB disk, put the 6TB disk and restore from the backup on the USB disk.
    • martin19's avatar
      martin19
      Yes in heinside that is what i should of done, if i set up the new disk, can i the install the 2 TB in the other drive and would that acheive anything.
      Thank you
      • StephenB's avatar
        No.  And in many cases, that will wipe the data on the 2 TB drive.
        If your 2 TB drive is intact, then you can still follow mdgm's procedure.
        • Power down the NAS,
        • Remove the 6 TB drive and restore the 2 TB model.
        • Power up the NAS - your data should be there.
        • Back up the data to a USB drive or possibly a PC internal drive.
        • Power down  the NAS again, and go back to the 6 TB drive (installed by itself).
        You can also try installing r-linux for windows on the PC, and see if that can access the data on the USB drive.
ProSupport for Business
