jcon1
Sep 03, 2013Aspirant
New WD Red 4TB Drives
I am almost at full capacity with 4 2TB Reds in my NetGear ReadyNAS Ultra 4 Plus, was planning to buy 3TB drives but just noticed WD has a 4TB Red that was just released. I know they aren't on the HCL...
mdgm-ntgr
Sep 04, 2013NETGEAR Employee Retired
You could go with 4TB drives but be aware of the support issues and that depending on what disks were in the NAS when you last did a factory default you may hit an expansion limit (see above) in which case you should backup your data and do a factory default then restore your data from backup.
