tuwat
Dec 03, 2018Aspirant
No access to Dashboard (configuration)
The ReadyNas has the final firmware 5.3.13
Win 7 and WIN XP Browser Firefox and Internetexplorer. All with newest patches.
When Connected to my second LAN Input 192.168.2.xxx without internet ac...
Dec 03, 2018Guru - Experienced User
tuwat wrote:
192.168.2.25 uses an invalid security certificate.
The certificate is not trusted because it was signed by the issuer himself.
Error code: SEC_ERROR_UNKNOWN_ISSUER
Add an exception
All ReadyNAS use self-signed certificates, so you will either need to add the exception, or click through the browser warning. The connection is still encrypted, the security concern is that a man-in-the-middle attack is possible (a server that somehow gets between your client and the NAS could also use a self-signed certificate with 192.168.2.25 as it's IP address). It's not a concern on your home network, but could be if you access the NAS over the internet.
Personally I don't recommend allowing internet access for a legacy ReadyNAS anyway, since it is no longer receiving firmware updates with security patches.
tuwat wrote:
When my ReadyNAS is connected to the switch of my internetconnection at first LAN input of my PC , 192.168.2.xxx too, I get the Following Message.
Error: Connection failed
Likely the PC IP address for that LAN port is misconfigured. Another possibility is that the NAS is using DHCP, and is failing over to a different IP address when you directly connect it to the PC LAN port.
Can you give us more information on the connection path? What IP address is the PC using for that LAN port? Also, check with RAIDar, and tell us what IP address it is showing for the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
