tuwat
Dec 03, 2018Aspirant
No access to Dashboard (configuration)
The ReadyNas has the final firmware 5.3.13
Win 7 and WIN XP Browser Firefox and Internetexplorer. All with newest patches.
When Connected to my second LAN Input 192.168.2.xxx without internet ac...
Dec 04, 2018Guru - Experienced User
tuwat wrote:
My second LAN-Port has the IP 192.168.2.2 (without internetaccess)
With no standard Gateway and DNS server assigned.
From here I can access my ReadyNAS dashboard with warning messages and exception agreement.
My first LAN-Port has the IP 192.168.2.3
DHCP is configured from 192.168.2.50 to 192.168.2.100.
The ReadyNAS has the fixed IP 192.168.2.25
When the ReadyNAS ist connected to this LAN, connection of Dashboard is refused without possibility for an exception agreement.
The middle Button gives me access to my data in both mentioned configurations.
This is one I haven't seen before.
One way to verify internet access is to download the log zip file when the NAS is directly connected to the PC. Then search system.log in the zip file for NTP time sync messages. If the time is being synced, then the NAS is connected to the internet.
I don't own an OS 5 NAS, so I don't know the format of the NTP message in the log.exactly what format the NTP message will use. Some ReadyNAS use this format:
ntpdate[17233]: step time server x.x.x.x offset 0.250609 sec
Others use
ntp: adjust (slew): -0.002835 sec
On the main problem - can you reach the NAS admin page using a different device (another PC, or maybe a phone)? Just browse to http://192.168.2.25/admin in the devices browser. Alternatively, try disabling the second (192.168.2.2) LAN port, and see if the behavior changes.
Do you have internet security software enabled on the PC?
tuwat
Dec 05, 2018Aspirant
Thank you for helping me.
After several shutdowns and restarts the device works normally again. Other cable connections were chosen.
I can not reproduce the malfunction.
Thank you very much.
