Stan78
Dec 16, 2018Aspirant
No access to shares nor to admin page
Halo guys. Have a big problem.
My NAS is Readynas Pro 6, running 6.10.0-T185
All of the sudden I lost possibility to open shares, admin page and even transmission page.
Ping is working fine. IP...
Dec 17, 2018Guru - Experienced User
- Stan78Dec 17, 2018Aspirant
Hi, Thanks forreply :)
Well....this was supossed to be a backup...
I do not mind movies, music and stuff, but I just was replacing my workstation which I use to do my job stuff, so I have moved about 2 Tb of important data to the NAS, checked for consistency and destroyed the source...Well... it turns out now I have a problem...:(
Since it is responding to ping, and I can ssh as root to it, I was thinking... Maybe it is possible to reasamble raid using LVM or mdadm ? It is inactive, not destroyed or degraded after all... Problem is I do not know Netgear specific changes done to regular Linux...
- StephenBDec 17, 2018Guru - Experienced User
A "backup" by definition is not primary storage. So if it is a backup, then all the data you care about is also saved elsewhere.
RAID alone is not enough to keep your data safe, and in your case Netgear support is not available to you since you are running OS-6 on a legacy NAS.
On top of that you are running beta firmware. However, that could work in your favor, as Netgear might want to analyze what happened.
The SMP error generally is a memory-related issue (for instance de-referencing a null pointer). So you might want to check the memory seating and run the boot-menu memory diagnostic. Another test would be to remove all the drives (labeling by slot), and doing a factory install to a test disk (that you don't mind reformatting). That would give you reasonable confirmation that the chassis is working normally.
OS-6 does use mdadm, but this is a btrfs error. That sugggests that the RAID array is assembled correctly, but there is file system corruption. Note the OS partition itself is also formatted as btrfs. You could try booting the system into tech support mode. From there, you can enter the commands below to mount the data volume as read-only. Note this assumes a healthy array, so you likely will get an error somewhere along the way.
# start_raids
# rnutil chroot
# btrfs device scan
# btrfs fi show
# mount -o -ro /dev/md127 /data- Stan78Dec 17, 2018Aspirant
Wow :)
Many thanks for this... I'd never think about memory modules....
Well... so far I did the first part... ran memory test...
3 passes total (1 sucessful, 2 with error) - went strangly quick (3 passes took below 20 minutes together, 2x2gb PC2 modules, 4Gb in total)...
So I replaced memory modules (I put 2x1Gb PC2) and ran test... this time, 3 pasess took nearly 60 minutes (while it was just half of original capacity) and no errors...
So I left the new memory in and ran the device.
Still no joy - RAID inactive... but this time... RAIDar diagnostics says :
System
- Volume data is inactive
Logs
- No errors found.
So... looks like it is a bit better... More of that... admin page still not working (not even Neatgear logo or so - just regular page not found), but I can now see the shares in windows...I can't open them tough - getting windows error 0x80070035 - network path not found...
I will be proceeding further :)
