claynz
Jun 10, 2021Guide
NO drive temp
Disk 4 shows no temputure, can anyone help me to fix this?
Jun 11, 2021Guru - Experienced User
Does it never show the temperature, or just sometimes?
Is disk spindown enabled on the NAS?
claynz
Jun 11, 2021Guide
As far as I know it has always shown the temp until I went in there yesterday and noticed it was empty
Yes, disk spindown is enabled on the NAS
I went into Disk 4 shares through the Web UI and I could hear the drive spinning up and now it shows the temp.
Disk 4 is used for backing up XBOX and PS3 games so I rearely access it and it is a good thing that it doesn't spin up with the others and would like to do the same with Disk 1 now
