babaraccas
Mar 27, 2013Aspirant
No filesystem on USB NTFS drive that worked perfectly fine
I disconnected a 1TB USB seagate drive from my ReadyNAS Duo v1. The drive was working totally fine and formatted as NTFS. I keep all of my movies and video files on it. I connected the drive directly ...
Mar 28, 2013Guru - Experienced User
You could try restarting the duo with the USB drive attached.
