babaraccas
Mar 27, 2013Aspirant
No filesystem on USB NTFS drive that worked perfectly fine
I disconnected a 1TB USB seagate drive from my ReadyNAS Duo v1. The drive was working totally fine and formatted as NTFS. I keep all of my movies and video files on it. I connected the drive directly ...
babaraccas
Mar 28, 2013Aspirant
I just tried to clean the USB list using the Clean_USB_Storage add-on as a long shot. No help.
I plugged the drive back into my Mac and again, all the files show up no problem. Disk Utility says the disk is formatted NTFS with 1 partition. The Partition Map Scheme is Master Boot Record.
