Denis1
Jun 05, 2022Tutor
no raid on a business Pro edition
I was looking looking something on plex when it was reporting no playable media. I figured that some how plex crashed. Restarted plex same thing. OK, I rebooted the nas and to my surprise the nas say...
Denis1
Jun 30, 2022Tutor
I'm not ready to give up. There are people here or out there who know how to fix btrfs tree errors. Just need to find them.
rn_enthusiast
Jul 07, 2022Virtuoso
I will take a look for Denis1
Was off the forums for a while, traveling a bit and such.
- Denis1Jul 18, 2022Tutor
OK, so I found a way to get to my data. I off loaded to two drives and now I wish to do a factory reset of my readynas Pro Business Edition. For the life of me I can't remember how I did the reset last time. I looked around but nothing works. So, I preset the reset button in the back, I press the power button. I get to the menu and select factory default. I press the power button and it boot normally, no reset has happened. What an I doing wrong?
- StephenBJul 18, 2022Guru - Experienced User
The process is on pages 28-29 here: https://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf The last step is to press and release the reset button again.
Another option is to simply unformat the disks (say with Windows disk manager), or zero them. Then just put in the NAS and power up. The NAS will detect that the disks are unformatted, and do a factory install w/o the boot menu.
Done, I'm loading my data. Installed Plex and now for Logitech Media Server. I look at the latest version of 7.9. Has anyone installed logitechmediaserver_7.9.3_all.deb? And from my memory all I need is to install logitechmediaserver_7.9.3_all.deb and then lms_1.0.9_all.deb. And that should be it; if I remember correctly.
