tomiaurednik
Feb 22, 2019Tutor
No volume exists
Yesterday in the morning NAS started to behave extremely slow. Found out it was stuck in a rsync process for days (replication to another NAS), but I was unable to stop the process. So NAS was restar...
Feb 23, 2019Guru - Experienced User
It's best to use paid support (my.netgear.com) for this. Ask about per-incident support.
Hopchen
Feb 24, 2019Prodigy
Yup, I agree with StephenB. This looks like filesystem corruption. Unless you are very familiar with BTRFS troubleshooting, I would think it is better that Netgear support takes a look at this. If you have backups you can of course factory reset the NAS and restore from the backups but otherwise it would be better to reach out to NTGR for assistance.
- tomiaurednikFeb 25, 2019Tutor
Maybe I am a bit stupid, but I cannot find anything else but call support. There's no pay-per-incident option for EU. Or am I missing something ?
Best regards
- StephenBFeb 25, 2019Guru - Experienced User
When you contact support, you can ask about per-incident support.
Use my.netgear.com to reach them.
I am slowly giving up on Netgear... I cannot find a way to request a support. This is how far I've got.
Contact NETGEAR Support
Thanks! We’re ready to help you with this product:
Product Model:RN10400Purchase Date2014-03-20Suggested Answers from our Knowledge base:
How do I access the boot menu on my ReadyNAS 104, 204, 214, or 314?Installing a Certificate on Google Chrome for ReadyNAS OS 6What are bonded adapters and how do they work with my ReadyNAS OS 6 storage system?I can no longer access my ReadyNAS OS 6 storage system after moving Local Area Network (LAN)ReadyNAS OS 6: SMB Plus AppReadyNAS OS 6: Setting Active Directory folder permissionsHow does my ReadyNAS OS 6 storage system use snapshots to protect my data?ReadyNAS OS 6: Setting a Static IPHow do I create a volume on my ReadyNAS OS 6 storage system?How to diagnose backup job failures on a ReadyNAS OS 6 systemShow more answers related to my question
I cannot find an answer to my problem, I would like to contact NETGEAR support.Based on your serial number and purchase date, NETGEAR can offer you the following support options:
Complimentary
Paid
Your complimentary 90 days technical support expired on 2014-06-18.
Your product hardware warranty expired on 2017-03-19.
