emma_brad2000's avatar
Dec 02, 2022
No Volume
Readynas Drive is showing no Volume and now i'm unable to access my data.
RN104 – ReadyNAS 100 Series 4- Bay
Is there a recovery method?
  • StephenB's avatar
    1. No volume?  Or an inactive volume?
    2. Have you downloaded the log zip file?
    3. Do you have any idea of what might have caused this (disk failure, unexpected power cut, forcible shutdown of the NAS, etc)?
    • emma_brad2000's avatar
      emma_brad2000
      Disk failure, i tried to replace the failed disk and then it was showing no volume.
      disk 1 is the new disk, i've tried different options but unable to see any shares.
      • StephenB's avatar
        It is actually showing an inactive volume (at the top of the page).
        1. Looks like the failed disk was disk 2 - is that correct?
        2. Was the volume showing a degraded status when you replaced the disk?
        3. Also, did you hot-swap the disk, or do something else?
ProSupport for Business
