la5vsa
Jan 26, 2015Aspirant
NV+ & 3TB Drives
Hi. Just tryed to install a NV+ for an company. I replaced 2 X 1TB drives with 4 X 3TB drives, factory reset & changed to raidlevel 5. But it can only see the drives as 1tb drives... Am running...
RX
Jan 26, 2015Luminary
la5vsa wrote: Other model from Netgear i can use my drives ?
I recommend you the Intel-based ReadyNAS OS 6 models like RN314. Check the specs here: http://netgear.com/images/pdf/ReadyNAS_ ... 700_DS.pdf
Be sure that you have a backup of the data from your NV+ v1 so that you could just restore it if ever you have purchased a new ReadyNAS OS 6 model.
