jawknee
Aug 07, 2011Aspirant
NV+ 2TB Limit - Was Disappointed, Now Happy
I bought an NV+ a couple of years back and was happy to see the improved support for Timemachine. But, with just 2 1TB drives I was limited to ~600GB. I did my research and settled on the Western D...
mdgm-ntgr
Aug 07, 2011NETGEAR Employee Retired
Though unsupported you can backup your Macs to different shares. You can set a quota for the user granted access to these shares up to 2TB. So you could have one/more Macs backing up to the supported share, and others backing up to other shares.
If using Lion you'll need to add "options:tm" into the Netatalk config for the ordinary shares you wish to backup to. See http://www.readynas.com/forum/viewtopic.php?f=71&t=55166
You'll also want to configure the ordinary share you are backing up to, to mount when the user logs in.
