jawknee
Aug 07, 2011Aspirant
NV+ 2TB Limit - Was Disappointed, Now Happy
I bought an NV+ a couple of years back and was happy to see the improved support for Timemachine. But, with just 2 1TB drives I was limited to ~600GB. I did my research and settled on the Western D...
jawknee
Aug 08, 2011Aspirant
OK - I set up a StudioBackup share and user. I'm not sure how to "configure the ordinary share you are backing up to, to mount when the user logs in." I noted that the user's home dir in /etc/passwd was /tmp - I changed that to /c/StudioBackup and changed /bin/false to /bin/true - still not showing up. I set the user to use /bin/bash, logged in and confirmed that /c/StudioBackup is in place. It wasn't clear to me - do I need to upgrade to Lion to use the new share? If so - that may be a while - Avid can take a while before ProTools can run on the latest s/w. If I don't need Lion, I'm apparently still missing something - but I'll take a another look tomorrow.
Thanks!
Thanks!
